VSS implementation
abeid
Does 12.2(33)-SXH2a support supervisor engine redundancy within the chassis.
6 Replies 6
satish_zanjurne
Level 9
Level 9
If Active sup and Standby Sup is in same chassis, it supports redundancy.
Satish, I didn't think VSS yet supported redundant sups in the same chassis. Could you provide a reference?
PS:
Prasanth, often we avoid multiple posts on the same question so all can follow a single thread of answers.
Right !!! it does not support multiple SUP's with virtual switch member.
But this restriction will be removed in a future software release.
Appoloize for same!!!
Ah! Thanks for the reply and do you know which release it is going to support ? is it SXH3 ?
No idea !!!
Hi Satish,
If we are running VSS on the core switches, can we run spanning tree on the below layers ?
