VSS Load Balancing
un-fald_2
Community Member
Dear all,
    I have configured VSS in two core distribution with port-channel and eigrp, but when I type show ip route it is showing only one side traffic(one Port-channel). If I shutdown that port-channel, I am unable reach the vss. Is there any command to do the load balancing with port-channel.
Selvam
Reza Sharifi
So, you have a switch that connected to a VSS pair via a portchannel?
if yes, than if you shut the portchannel all links in that portchannel go down.  You need to down a port in the portchannel and not the portchannel itself
What is the design look like?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
On non-VSS devices, load sharing commands, i.e. what's available, and default vary by platform.  Most newer platforms support multiple options.
On VSS devices, it ignores load sharing between VSS members, as VSS tries to keep all dataflows from crossing VSL links.  If there are multiple links on same member, I suspect that device load sharing options might apply.
