VSS PFC3C etherchannel hash result
nick.davey
I am trying to determine the egress interface using the hash-result command as follows:
show etherchannel load-balance hash-result interface po 2 switch 1 mixed 10.64.2.2 200 122 10.64.2.1 200
I have noticed in that command that there is a "ignr-dst-vlan" option on the command that is marked as PFC3C only, for example:
show etherchannel load-balance hash-result interface po 2 switch 1 mixed 10.64.2.2 200 122 10.64.2.1 200 ?
  ignr-dst-vlan  Ignore destination VLAN (PFC3C only)
My load-balance algorithm is "src-dst-mixed-ip-port vlan included" - does this mean in a PFC3C system the destination vlan is ignored when computing the hash and in a PFC3X system it is used?
I cant find any documentation on destination vlan for etherchannels.
Nicky Davey.
Hi Nicky,
I verified on lab, which has VS-S720-10G with PFC3CXL and i can see the same behavior,
VSS#show etherchannel load-balance hash-result interface port-channel 105 switch 1 mixed 10.10.10.20 200 1 10.10.10.1 200 ?
Aru
Regards, Aru *** Please rate if the post useful ***
Reza Sharifi
Hi Nick,
It appear to be so, as I also tried this command on a Sup-2T with PFC4 and it shows the same thing.
Hi Reza,
So you have come to the same conclusion as me, that the PFC3C does not include the destination vlan in the load-balancing algorithm.
Is there anyone from cisco that could confirm this as I dont want to make an assumption?
Nicky Davey.
Hi Nicky,
Aru
