vss quad sup questions
carl_townshend
hi all, i have copme across vss quad sup setup
How do I reload the standby sup in the same chassis ? if I do a >redundancy reload peer, this will reload the sup in the other chassis.
how is this achieved ?
Giuseppe Larosa
Hello Carl,
according to documentation the in chassis standby supervisor is seen as a linecard with DFC module.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1204229
You can initiate a z-switchover by entering the
redundancy force switchover
command on the in-chassis active supervisor engine. You can verify the  switchover mode of the supervisor engines by entering the
show module
command.
However, this is not what you are looking for.
To reload the in chassis standby supervisor I would try to do the following:
use show module to find the slot number of the in chassis standby supervisor
then using hw-module command you should be able to reload the module at position slot#
Edit:
hw-module reset
To reset a module by turning the power off and then on, use the hw-module reset command in privileged EXEC mode.
hw-module module num reset
where num is the slot number
WARNING:  this procedure should be tested in a lab environment it is not recommended to test it in production
Hope to help
Giuseppe
Giuseppe Larosa
Hello Carl,
see
show module
command.
Edit:
hw-module reset
Hope to help
Giuseppe
