VSS Supervisor Enginee
compnet.mtc
Hi guys.
I need an advice about vss.
I would like to configuring VSS on 6500. From my understanding, the ios version must be identicaly match and same goes with  PFC version.
I have Sup2T-10 (PFC4) and Sup2T-10-XL (PFC4-XL).
Can vss work with both supervisor? Or should i use "platform hardware vsl pfc mode non-XL" command?
Reza Sharifi
Yes, you have to downgrade XL Sup to regular Sup with the command you posted, if not VSS will not work because the Sups are not compatible.
