Cisco 887VA VDSL Port Forwarding
TacticalKitchen
Hi Guys,
For some reason I am a little rusty on the subject of getting this to work.... Can someone please tell me what I'm doing wrong?
Just trying to port forward to the wan int (which i believe is Dialer1) a few ports like 8080 from a host on the network and for some reason what even I do.... like: ip nat inside source static tcp 192.168.1.2 8080 interface dialer 1 8080 just doesn't seem to work.
Thanks in advance :)
Current configuration : 3932 bytes
! No configuration change since last restart
version 15.1
no service pad
service password-encryption
hostname VDSL
boot-start-marker
boot-end-marker
enable password 7 ***********
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-949938359
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-949938359
revocation-check none
rsakeypair TP-self-signed-949938359
crypto pki certificate chain TP-self-signed-949938359
certificate self-signed 01
quit
ip source-route
ip dhcp excluded-address 192.168.0.0 192.168.0.10
ip dhcp excluded-address 192.168.0.100 192.168.0.255
ip dhcp pool dhcp1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip cef
no ip domain lookup
ip dhcp-server 192.168.1.1
no ipv6 cef
username admin privilege 15 secret 4 *******************
controller VDSL 0
interface Ethernet0
no ip address
interface Ethernet0.10
encapsulation dot1Q 10
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
description Internal Switching between various switches and AP's
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1380
interface Dialer1
ip address negotiated
ip access-group 103 in
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname user@spark.co.nz
ppp chap password 7 13151601181B0B382F
ppp pap sent-username user@xtrabb.co.nz password 7 140713181F13253920
hold-queue 224 in
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.2 8080 interface Dialer1 8080
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
line con 0
line aux 0
line vty 0 4
password 7 **********************
login
transport input all
end
TacticalKitchen
I've tried a few more ip nat inside source static tcp 192.168.1.2 8080 interface Dialer1 8080 type commands but still no joy. I'm starting to think I need some sort of outbound NAT on ethernet0 or 0.10 (which is my isp VID). Any ideas?
Damn.... I'm really not getting anywhere.
