VSS switch setup
Let say I have one router connected to two distribution switches called and A and B and obviously there is are trunk between them and they both running VSS and distribution A switch is the master and B standby, then the access switch 1 is connected to both distribution switch A and B.  Let say the port that access switch is connected to distribution B as well as all the physical trunks between the two distribution switches goes down completetly can the distribution switch A foward packets from the access swithch to the router.  At this point there is only connectivity from the distribution switch A to the  access switch. Also would this scenario work if I use HSRP instead of VSS?
Reza Sharifi
First, one the benefit of VSS is that you don't need VRRP, HSRP, etc...
As long as your access switch has connectivity to both switch A and B using Etherchannel, If the switch B and the link between the VSS pair fail, you can still forward traffic using switch A.
Reza
Reza Sharifi
Reza
