vss uplink from a closet
DARYLE DIANIS
I believe I understand that MEC on a VSS can be Layer 2 or Layer 3.  Is that correct?  Is one better than the other?  For simplicity, it seems a Layer 2 link might be easier.  Are there pro's and con's?
thanks,
Reza Sharifi
MEC with VSS is layer-2:
Q. What is multichassis EtherChannel?
A. Multichassis EtherChannel (MEC) is a Layer 2 multipathing technology.  This form of EtherChannel allows a connected node to terminate the  EtherChannel across the two physical Cisco Catalyst 6500 Series Switches  that make up the VSS leading to creating simplified loop-free Layer 2  topology. Using MEC in VSS topology results in all links being active  and at the same time provides for a highly available topology without  the dependency of Spanning Tree Protocol. With the introduction of  12.2(33)SXI, the virtual switching system supports a maximum number of  512 MECs.
More info here:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b.html
thanks for the info, I've been reading from this document, too:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/VSS30dg/VSS-dg_ch3.html#wp1102944
and it discusses Layer 2 and Layer 3 MEC. If a person had a choice between using Layer 2 or Layer 3 uplinks to a VSS, which choice would be better or is it one of those "it depends" kind of thing.
thanks,
Usually when you uplink your access devices to VSS, it is layer-2 portchannel (MEC) from the access switch to both 6500 switches with SVIs on them. This eliminates VRRP, HSRP, Spanning tree etc....
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Generally, the VSS uplink would be whatever you might have used if VSS wasn't available and you are working with a single physical device.  I.e. if you would have used L2, VSS uplink is likely to still be L2.  If you would have used a L3, VSS uplink is likely to still be L3.
