Michael,
I was wondering too when configuring our 6807s for VSS. Maybe below will give some inputs.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/VSS30dg/campusVSS_DG/VSS-dg_ch2.html
VSL Characteristics
The VSL port channel is treated as an internal systems link. As a result, its configuration, resiliency, mode of operation, quality of service (QoS), and traffic load sharing follow a set of rules that are specific to VSL. This section covers configuration requirements relating to those rules. The logical port channel and its member link both have distinct sets of restrictions.
VSL protocol(VSLP) runs VSL, that follows its own sets of rules to manage the link.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-virtual-switching-system-1440/109547-vss-best-practices.html
VSS Terminology
Virtual Switch Link (VSL)—A special port channel required to bundle two physical switches into one virtual switch.
VSL Protocol (VSLP)—Runs between active and standby switch over the VSL, and has two components: LMP and RRP
***Please rate and mark the comment correct if you find it helpful. Thanks***
