VSS with quad SUP6T on C6807-XL
Nabil.awad1
What is the best practice to design VSS on pair of Catalyst 6807 using quad SUP6T setup? How many domains to configure? and supported SW releases -- Thanks
Correct. The config is the same but I recommend you test the fail-over with 4 sups before putting the chassis in production. BTW, I don't have any  Sup-6T yet but it should be the same as Sup-2T
Thanks Reva Shari -- sounds looks great So it is supported design ??  and VSS configuration same for 2sup like 4sups ?
