VSS with SUP 2T
garry cordess
Is there a document that states that the services modules are supported on the SUP2T in VSS?
I have looked and there are documents for the SUP720 but not for the SUP2T.
Modules I am looking at are:
ACE30-MOD-K9
WISM-SVC-WISM-1-K9
WS-SVC-ASA-SM1-K9
I think that these services modules are supported in VSS but want to make sure. I know there is a bug on Cisco Config Tool that says the WS-SVC-ASA-SM1 isn't supported with the SUP2T, after checking the release notes I can ignore the bug.
Garry
Hi Garry,
ACE30 Is already supported
Virtual Switching System Support
The ACE30 running ACE software version A4(1.0) or later releases and  installed in a Catalyst 6500 series switch running Cisco IOS release  12.2(33)SXI4 or later releases support the Virtual Switching System  (VSS). VSS is a system virtualization technology that allows the pooling  of multiple Catalyst 6500 switches into a single virtual switch for  increased operational efficiency by simplifying the network.  Inter-chassis Supervisor switchover (SSO) boosts non-stop communication.  For more information about VSS, see the Cisco IOS Version 12.2(33)SXI4 Configuration Guide.
here is the link:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA5_1_x/release/note/ACE_mod_rn_A51x.html#wp546319
6 Replies 6
Reza Sharifi
Here are the supported service module that can be used in VSS using Sup 2T
Q. Which service modules are supported with Cisco Supervisor Engine 2T?
A. The following service modules are supported: Cisco Catalyst 6500 Series  Firewall Services Module (FWSM), Cisco Adaptive Security Appliances  (ASA) service module, Cisco Application Control Engine (ACE) 20, and  Cisco Catalyst 6500 Series/7600 Series Wireless Services Module (WiSM)  and WiSM-2.
Part Number
Product Description
ACE20
Cisco Catalyst 6500 Application Control Engine 20 Hardware
NAM-1
Cisco Catalyst 6500 Network Analysis Module 1
NAM-2
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps11878/qa_c67-648478.html
FWSM
Cisco Catalyst 6500 Firewall Service Module
WISM
Cisco Catalyst 6500 Wireless Service Module
WISM2
Cisco Catalyst 6500 Wireless Services Module 2
Here is the link:
garry cordess
Hi Reza,
Ok thanks for the reply.
So we can assume (at least at the moment) that the ACE30-MOD-K9 and the WS-SVC-ASA-SM1 are not supported?
Garry.
Hi Garry,
here is the link:
Hi Reza,
Ok, many thanks.
Garry.
smailmilak
Level 4
Level 4
Unfortunately Cisco Workspace and a document say that ACE30 is not supported with SUP2T.
Here is the document where SUP2T is not stated under supported supervisors:
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/product_bulletin_c25_632385.html
and Cisco Workspace gives me this message:
SC6K-A41-ACE is  incompatible with VS-S2T-10G
IOS version with is selectable is S2TAIK9-15001SY and I can only select IOS versions with SY, not SXI.
Here is a document where it cleary says that ACE is supported on SUP2T
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6906/data_sheet_c78_632383.html
Today is the Cisco Dynamic Configuration Tool not working and I need it really bad because I have more options.
Talk to your local Cisco Sales Engineer or Account Manager.  Make sure you get this in writing.
