11-25-2014 07:19 AM - edited 03-10-2019 12:29 PM
Can you please help me for configure Virtual Switching System (VSS) in switch catalyst WS-C4510R+E SUP8-E.
thank you,
11-25-2014 07:36 AM
Here is the config guide with config example:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/vss.html
11-27-2014 12:37 AM
Hi Reza,
thank you for your reply. your answer is for switch Supervisor Engine 7-E, Supervisor Engine 7L-E, and Catalyst 4500-X,but my question is for WS-C4510R+E with 8 supervisor.
Thank you,
11-27-2014 06:51 AM
VSS config should be the same for all the 4500 series switches regardless of the model.
11-28-2014 02:31 AM
Thank you reza .
04-04-2015 10:50 AM
I want to know if IOS 6.6 and 6.7 of 4500 sup8 are stable or no for configure VSS???
Thank you.
