VTP Mode
vinoth.kumar
We are using 6506 as our core switch and 4948 switch for our 10 Gg interconnectivity for some reason i need to disable the VTP in my 4948 which is already working in LIVE production
can i change the VTP mode from server to transparent in the LIVE traffic is there
Vinoth,
Yes, You can. You are going to change the mode. You will see VLAN information in the running configuration. After that you can add/remove VLANs you want.
Toshi
