VTP pruning
dennisv99
Community Member
Hi all,
I'm studying on the 642-813 exam and i can't get a clear anwser on the floowing question about VTP pruning
(see picture attached)
The certification guide states that broadcasts and unicast floodings on a vlan are blocked on trunks to switches which doesn't have interfaces in that vlan.
The picture shows broadcast traffic send from host A to host B. Why is this broadcast traffic passed along switch 2 which doesn't have interfaces in the Red vlan?
thanx in advance
Jon Marshall
Dennis
Assuming host A connected to switch 4 and host B connected to switch 1 and host A sends packet to host B.
VTP pruning works in a chain so to speak. So if host A and host B are in the same vlan then switch 2 cannot prune that vlan because switch 1 and switch 4 both have hosts in that vlan. If switch 2 pruned the vlan then host A would send the packet to switch 4 but then switch 4 could not forward it on to switch 2 and therefore the hosts would not be able to communicate.
That is what i mean by a chain ie. switch 2 is an intermediary switch in the chain from switch 1 to switch 4 and both switch 1 and switch 4 have hosts in the same vlan so there will be no pruning on switch 2 for that vlan.
If switch 1 did not contain a host in the same vlan as the host on switch 4 then switch 2 could indeed prune the vlan.
Jon
Hi John,
Thanx for the swift reply.
It still isn't quite clear to me.
If i understand it correct vtp pruning works by a switch sending a message to a neighbouring switch if it has ports in a particular vlan. If it doesn't the neighbour switch prunes that vlan on the trunk to that switch.
In the drawing switch 2 doesn't have ports in vlan Red so to my logic switch 1 and switch 4 should prune vlan Red on the trunk to switch 2 because switch 2 does not advertise it has ports in vlan Red.
And what if there were more switches between ie switch 1 and 2 that also don't have access ports in vlan Red?
Dennis
If there were more switches in between then they 2 would not be pruned. Think of it like this -
switch 2 cannot send a prune message to switch 4 until it knows there are no downstream switches that have members in that vlan. If switch 1 did not have any members in that vlan and because there are no downstream switches connected to switch 1 it can send a  prune message to switch 2. Switch 2 could then send a prune message to switch 4 because it too doesn't have any ports in that vlan (other than trunk ports that is).
However because switch 1 does have a member port in that vlan then it does not send a prune message to switch 2. So switch 2 knows that switch 1 has connected host in that vlan. So switch 2 does not send a prune message to switch 4 because it knows it needs to forward packets for that host to switch 1.
That is what i meant when i said it was a chain.
Jon
Thanks Jon,
It's perfectly clear to me now
