VTP question
Rafael Jimenez
Level 7
Level 7
I had to put two switchs with Vlans. I want a router on the stick (2821).I dont have a switch that support vtp server mode, I just have two catalyst express 500 switchs. I would like to know if there is a problem with this configuration.
No, you shouldn't have any problem with that.
VTP is a mechanism through which the VLANs are dynamically propagated. This simplifies the VLAN configuration process as any changes made on a central device, VTP server, is propagated to the other switches in same VTP domain. This is useful for large networks with multiple switches.
Your setup doesn't require VTP as you have only two switches. Create the VLANs manually in the switches and configure sub interfaces on the 2821 router to route between the VLANs.
Sundar
