VWIC3 - 4MFT-T1/E1
ashleyreed4218
I need to configure a Cisco 2911. I need to give an interface in this module (VWIC3 - 4MFT-T1/E1) an IP address. My question is, does anyone know how to assign an IP to an interface in this module.
My purpose is to get connectivity via T1 line to another router.
Ashley
16 Replies 16
Hi Rick,
I was finally able to ping. You were correct. The issue was that I was using HDLC on my 2911 and my 6610, but I had to be using CHDLC (Cisco HDLC) on my 6610, since it is not a ciso device. The second part of the issue was that I had the speeds set to mismatch. For example, I had configured the controller group timesots 1-24 speed to 64k on my 2911, and the 6610 by default was set to 56k.
I went back in and made those changes, and bazinga I was able to ping and my serial interface protocol remained up. (Unlike before when it kept changing up/down/up/down).
Thank you for your help!
Warm Regards,
Ashley
Ashley
I am glad that you got it worked out and that my suggestions were helpful in this. Thank you for posting to the thread, telling us that it is now working and telling us what you had to do to get it to work. Perhaps there is something in this that will help some other reader of the forum.
Rick
Rick
