UDP Broadcast forwarding, Nexus
erick.whiteford
Customer is using Exterity product to stream TV to receivers placed around the LAN. Management of the receivers is done with a package which receives SNMP traps from the receivers before adding the receiver to the management database.
If the receiver is in a different VLAN from the management device the traps need to be forwarded to the “management” VLAN using an “ip helper-address”.
This is where I run into a problem as the Layer 3 is on a Nexus 7000 series running NX-OS (v5.1(1)) and it doesn’t appear to support the ip helper-address command, instead it uses the “ip dhcp relay address”.
Am I missing something or is there a way of forwarding UDP port 162 to a different VLAN on the Nexus?
Chad Peterson
Hi Erick,
The Nexus 7000 doesn't have support for routing broadcasts from one vlan to another.  Only time we do this is DHCP Relay (which translates broadcast to unicast).
Chad
Chad Peterson
Hi Erick,
Chad
Thanks Chad. That was the conclusion I had already come to, however, I wanted to run it past someone in the know in case I had missed something.
Hi Chad, do you know if it is planned to provide this functionality in the Nexus in future releases?
Sung Min Cho
Chad,
We need the routing broadcasts from one vlan to another for netbios protocol.
Any idea for dolving the this problem ?
Thank,
Sungmin
