VX-LAN SETUP
fmugambi
Hello Team, FAM!
Attached is my high-level topology between DCs, need help setting up vxlans, Please guide me ,
5 Replies 5
fmugambi
HI Team,
Any updates/help on this.
Thank you.
Enes Simnica
Hey man. As I was able to concentrate, coming from 16 hours of working nonstop. I tried to make the config as accurate as possible, even though 99% of my brain is shut down now, lool. Also, will try this on EVEng after some sleep... but here’s the precise config for your setup:
DC1 CORE SWITCH (ws-c3850-48T)
! Underlay (MPLS Link to DC2)
interface Gig1/0/1
 description MPLS_TO_DC2
 no switchport
 ip address 172.16.10.1 255.255.255.252  ! Your /30 link
! VXLAN Tunnel
interface Tunnel1
 description VXLAN_TO_DC2
 tunnel source 172.16.10.1
 tunnel destination 172.16.10.2
 tunnel mode vxlan
 vni 10000  ! Same VNI on both sides
! Overlay (Server VLAN)
vlan 100
 name DC1_SERVERS
interface Vlan100
 description VXLAN_SERVERS_DC1
 no shutdown
 vxlan vni 10000
! FortiGate Connection
interface Gig1/0/24
 description TO_DC1_FW
 switchport access vlan 100
! Static route to DC2 servers
ip route 192.168.30.0 255.255.255.0 172.16.10.2
DC2 CORE SWITCH (ws-c3850-48T)
! Mirror config, just flip IPs
interface Gig1/0/1
 description MPLS_TO_DC1
 no switchport
 ip address 172.16.10.2 255.255.255.252
interface Tunnel1
 description VXLAN_TO_DC1
 tunnel source 172.16.10.2
 tunnel destination 172.16.10.1
 tunnel mode vxlan
 vni 10000
vlan 100
 name DC2_SERVERS
interface Vlan100
 description VXLAN_SERVERS_DC2
 no shutdown
 vxlan vni 10000
interface Gig1/0/24
 description TO_DC2_FW
ip route 192.168.40.0 255.255.255.0 172.16.10.1
But also, Fortigate tweaks, meaning config for Cross-DC routing...:
On DC1FW (192.168.40.1):
config router static
  edit 0
    set dst 192.168.30.0 255.255.255.0   # DC2's subnet
    set gateway 192.168.40.254            # DC1 core's VLAN100 IP
    set device "port1"                    # Replace with your FortiGate interface
  next
end
And for the:
DC2FW (192.168.30.1):
  edit 0
    set dst 192.168.40.0 255.255.255.0   # DC1's subnet
    set gateway 192.168.30.254            # DC2 core's VLAN100 IP
  next
end
 If anything's wrong here, blame my sleep-deprived brain. it checked out hours ago loool!
Hope this helps man.
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
what if the fws the fgt connect to core via ospf on both dcs?
still need the static routing?
Hello @fmugambi
yes use dynamic routing beween Fgt and Core.
What about VxLAN tunnel ? All is OK ?
Best regards
fmugambi
testing this, will update with results.
Thank you.
