VxLAN Routing on Nexus 9300s
V120311
     I have a few questions regarding VxLAN Routing on the Nexus 9300s.  I have the below topology currently setup.
For vxlan routing I have configured my shared VNI segment which is shared across all leafs. So I am able to successfully route between different VxLAN segments. The weird thing that I see is when I perform a traceroute from SwitchB(Host2) towards SwitchC(Host3) I see the gateway IP that SwitchB(Host2) is using twice in the traceroute output. Is this normal behavior and will cause effects to the network.
Thank you,
0 Replies 0
