wake on lan setup for vpn
sahad15978
I have a remote user who has access to 192.168.10.0 subnet through a remote client to site VPN setup.  The address pool subnet that they receive thru DHCP at the router via VPN is the same as the Vlan that is on the switch that they are accessing.
I want to setup Wake On LAN to wake up one machine at 192.168.1.5.  Can someone help me with the configuration at the router and the configuration at the switch please?  I am new to this, so please try to be detailed with an example.
Thank you
Reza Sharifi
I think the "wake up lan" feature depends on the type of switch and the IOS version you are using.
Here is the config guide on how to enable it on the switch:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/91672-catl3-wol-vlans.html
