Wake on LAN through a Cisco Device
avilt
Level 3
Level 3
I have a branch office with a Cisco L2 switch and a router. I do not have any PC's online at the remote office. Is there any way to send wake on lan magic packet directly from the remote L2 switch or router to power on the remote PC's?
You Must have an ios that Supports tclsh and has The udp Library. 15.0 at least.
Try search google with "cisco ios Tcl wol" and you will find a Sample Script
BTW fixed URL should work
patrick.preuss
You have two options First you do The forwarding for The Magic packet.
Second you use a Script on The Router
http://blog.ioshints.info/2011/11/sending-wake-on-lan-wol-packet-with-ios.html
Hth
The url does not work. How can I run a script directly from the router?
