Walking-One / POST Failure
Dean Romanelli
Level 8
Level 8
Hi All,
Apologies if this is the wrong area for this, and please feel free to relocate.
I have a faulty 3750 at work that was given to me.  It's RMA is expired.  When booting, I get the following:
TCAM (asic:0) walking-one test failed
  Write: 80_00400000_00000000-00_00000000_00000000
  Read:  80_00000000_00000000-00_00000000_00000000
HTD POST: Walking Ones Test Failed
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
driver class subsystem initialization failed
!!! WARNING: The switch is not usable !!!
It appears that the main problem is that it doesn't think it has any interfaces installed.
Switch#show run
Building configuration...
Current configuration : 563 bytes
version 12.2
no service pad
no service dhcp
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
port-channel load-balance src-dst-ip
spanning-tree mode pvst
vlan internal allocation policy ascending
ip classless
ip http server
ip http secure-server
no cdp run
control-plane
line con 0
line vty 5 15
end
I would love to have a working 3750 for my home lab, so is there anything I can do to fix it, other than trashing it considering it's no longer under warranty?
Leo Laohoo
Nope, it's dead.
