Wan interface on VSS
i know sip400 is supported on VSS system since SXI4 or better on SXI4
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/features.html#wp4786761
but no info about which spa supported on VSS.
Do you know if SPA POS OC48 is supported on vss system ?
Planning  to buy the new 2T supervisor, i have the same question, is sip400 and  POS OC48 supported on 12.2.50 or 15.0 version on the 2T supervisor ?
many thanks for the help
Max
Fabienne Stephanoff
Max,
For VSS, please review the following:
http://www.cisco.com/en/US/partner/products/ps9336/products_tech_note09186a0080a7c72b.shtml
I am not aware of SPA support in sup2T but you may want to check with your Cisco account team.
Cheers,
Fabienne
LAN-Switching TAC
