WAN router with failover to external VPN device
fbarnett
Cisco 2811 with MPLS running RIPv2. What is the best way to configure VPN failover to another device (Juniper SSG-350) that is on the same LAN? Is this as simple as weighted static route?
Chip,
It was my typo again. It should be look like this:
ip route 20.0.0.0 255.0.0.0 10.100.100.1(Juniper) 130(AD)
HTH,
Toshi
Chip,
Just add static routes pointing to Juniper with higher AD than RIP. This should be fine.
HTH,
Toshi
Thanks for the quick response, what did you mean by "then RIP" ?
Thanks!
Chip,
HTH,
Toshi
ok, understand
Thanks for the quick help.
