Help with HSRP lab
whiteford
I would like to configure HSRP with 2 routers and a switch I have. The routers are 2620's which only have one ethernet port, can I practice HSRP with these at all, not sure if I can use a loopback or not?
mahmoodmkl
Level 7
Level 7
yeh u can configure HSRP with the above devices..
Why u want to use loopback IP's...?
Yes u can configure loopback interfaces.
Mahmood
lamav
Level 8
Level 8
Hi:
You can configure HSRP with what you have. You dont need loopback interfaces.
R1
interface GigabitEthernet0/1
ip address 138.69.164.251 255.255.252.0
standby 20 ip 138.69.164.250
standby 20 timers 3 6
standby 20 preempt
standby 20 priority 105
R2
ip address 138.69.164.252 255.255.252.0
standby 20 preempt
Victor
Thanks, this worked.
The router with "standby 20 priority 105" is this the main router as it always takes the active role when both routers are on?
