01-20-2022 12:39 PM
Hi, in our organization we will get second ISP connection for redundancy. We have only one firewall (not ha pair) at the edge. I want to know if we need wan switch between ISP connections and firewall. What will the advantages be?
Solved! Go to Solution.
01-20-2022 05:55 PM
Not sure what model ISP, if the ISP offers Ethernet, you can directly connect to the Firewall depending on the model.
You have 2 options :
1. You can split the load between ISP and do the Failover.
2. Only Failover if one ISP Fail, failover other ISP :
simple example config helps you as below :
https://integratingit.wordpress.com/2019/11/24/asa-dual-isp-using-ip-sla/
01-20-2022 12:47 PM
not really sure what you are after. A switch in front of the firewall ?
Do you have an ASA ? If both ISP connections terminate on the same ASA, a switch would not add anything.
You can configure the ASA for ISP redundancy:
01-20-2022 05:55 PM
