WAP 371: DIsconnecting after few minutes
RobinD
Hi guys
I have a really strange problem. I have a WAP 371 cluster with 7 APs, connected to a SG300-52P.
Since a few weeks the clients (iphones, W10 PCs) are constantly disconnecting after a few minutes. Sometimes the devices reconnected after a few minutes itself, sometimes I have to ignore the network manually and connect it again. Then after a few minutes the problem occurs again. The problem also occurs if I walk to the next AP and the device try to handover the connection to the next AP.
If I check the wifi settings, I see that i've got an APIPA adress, but the SSID is still broadcasted with full signal strength. It doesn't matter if I broadcast the 5GHz or the 2.4GHz.
I found some posts from users with the same or a similar problem with the WAP371, but I'm not sure of any of them were able to completly resolve this problem.
I've tried the following things:
-Disable green ethernet
-STP Disable
-Reset APs
-MFP set to not required
If I am connected over cable the networkconnection works fine.
Do anyone of you have an idea or a solution?
Greetings from switzerland (explains my english)
6 Replies 6
which Radio mode is active, 1 or 2 (page 84 of the attached guide) ? Try Radio 2...
https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap371/administration/guide/1_0_0_10/1CSWAP371-SWUM100_1_0_0_10.pdf
Tried both, the problem occurs with both radios.
which firmware release are you running (release 1.3.0.6 is the latest) ?
Currenty i'm running 1.3.0.6, I also checked 1.3.0.4. The older fw also doesn't work fine.
calverthall
Any progress on this?  I need to troubleshoot an environment with 4 371's that are reporting drop offs.
Last I checked, documentation says they are running 1.2.1.3
Austin
I am not sure whether your switch is a POE+ device or not.  I had issues running with POE and a small cluster using WAP371 units.  I bought a SG300-10 MPP switch which has POE+ support.  My issues went away using POE+ power.
