WCCP issue in Cisco 4900
CSCO11357378
Hi all
I am try to configurate WCCP in a Cisco 4900 device but I can´t do it, appear the following error:
Packet forwarding mismatch (The router does not support the forwarding method (GRE or L2)
This is our IOS version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.0(2)SG9, RELEASE SOFTWARE (fc2)
Any Idea?, Can you help me?
Reza Sharifi
Do you have any SVI or layer-3 interface enabled?
Not sure if this is your issue or not:
  • Global WCCP service configuration fails to enable (WCCP global config is accepted but nvgen fails) on a newly deployed switch if the switch is not enabled for SVI or a Layer 3 interface.
Workaround: Enable a Layer 3 interface in the running config. CSCsc88636.
Link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-1523e-4900m-4948e.html
Reza Sharifi
Link:
CSCO11357378
Hi Reza
This router is working as a layer-3 currently, any other idea?, Could be a version issue?
