3750- stack switch ios upgrade process
sumanitccna
Community Member
Hi All,
I want to upgrade 3750 stack ( 3- switch stacked ) . Could any one let me know which process will be the most efficient , less down time required .
3750 Series Switch Stack IOS Upgrade - Automatic (.tar image)
3750 Series Switch Stack IOS Upgrade - Manual (.tar image)
3750 Series Switch Stack IOS Upgrade - Manual (.bin Image)
Actually i want to install tra image / bin image during business hrs and want to reboot during down time.will it be possible.
Looking forward to your responce
7 Replies 7
Francesco Molino
Hi Tar image process is the best one and quite automatic, however it takes a lot of time while it's copying and extracting image within switches. What I'm doing all the time is: - copy bin file on each switch flash drive's - modify the boot variable on the master (be careful to indicate the new IOS for all switches) - Reboot them manually on evening or program the reboot through the switch itself. There is another way if you are using Cisco Prime. You can program everything and CPI will do everything fine during night. Thanks
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi All ,
Thanks you for clearing the confusion .I need one more information here.
Do i need to upgrade the sevice module also .AS those service module came with the devices .
Nothing more to do
Francesco
ALL,
Here is the service module
PID: C3KX-SM-10G
refer to the "Catalyst 3750-X and 3560-X Network Services Module Software" section in the following link.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/release/notes/OL25302.html#wp1048167
you can use "archive download-sw" command to perform the IOS upgrade and if the service module is incompatible with the new IOS,  it will inform you about that.
AFAIK, you dont need to. it should work fine.
whats the service module you are using.
Furose M
Level 8
Level 8
Manual Tar upgrade and BIN upgrade exactly same. if you are not going to use the Web GUI, you dont need to TAR image.
The automatic TAR method makes your job easy and you dont need to do anything.
i am a manual guy who always wants to see what is happening and wants to control what its doing. if you are such guy, you could go for manual bin method.
if you want everything to be automated and hoping not to run into any issues during the automatic method, you can go for auto TAR method.
if you being a manual guy and wants to have GUI access, go for manual TAR method..
now, the choice is yours.
