WCCP on 6500 with Squid Proxy
David.Pellat
I have been tasked to setup a Transparent Squid proxy and do redirection on  a Cisco 6513 Switch.
I don't have access to the SQUID but think that my config below should be OK. We have setup a TEST user Vlan 13 . Any traffic from this destined for the we on 80 or 443 should be redirected.
Vlan 10 is where the Squid proxy is sitting.
ip wccp version 2
ip wccp web-cache group-list 10 password xxxxxxx - Limit the servers that can operate WCCP with the switch.
access-list 10 remark WCCP_SQUID_PROXY
access-list 10 permit host 10.20.10.50 (Squid Server)
ip wccp web-cache accelerated  - Enables the hardware acceleration on PFC cards
ip access-list extended WCCP_REDIRECT  -
permit tcp 10.20.13.0 0.0.0.255 any eq www
permit tcp 10.20.13.0 0.0.0.255 any eq 443
deny ip any any
ip wccp redirect-list WCCP_REDIRECT
interface vlan 13
desc TEST_USER_FOR_SQUID
10.20.13.1 255.255.255.0
ip wccp web-cache redirect in (Coming into vlan from internal subnet for any on TCP 80 and 443 gets redirected)
interface vlan 10
dest SQUID_SUBNET
10.20.10.1 255.255.255.0
Please can you let me know if there is anyting that i am missing? Thanks
David
Giuseppe Larosa
Hello David,
WCCP should need a L3 point of application for example in your case for the testing phase I would add
interface vlan13
ip wccp web-cache redirect-in
see
http://www.cisco.com/en/US/docs/ios/12_2/configfun/configuration/guide/fcf018_ps1835_TSD_Products_Configuration_Guide_Chapter.html#wp1001302
in alternative the redirect out can be used on the interface towards internet.
Hope to help
Giuseppe
Hi Giuseppe,
I had added this in above?  Only traffic from the vlan 13 configured in ACL WCCP_REDIRECT  will redirect to the SQUID.
By using "ip wccp web-cache accelerated" this should enable the wccp in hardware?
By Using |ip wccp web-cache group-list 10 password xxxxxxx" restricts on the server defined in the ACL to connect to the router for wccp.
I think I have the bases covered?
Thansk
Hello David,
I agree your configuration should be fine.
according to documentation
ip wccp web-cache group-list 10  restricts with what caches the router will peer using WCCP protocol
I'm not sure on this it should do it.
Hope to help
Giuseppe
