WCCP redirection not working on Catalyst 4500
randms2610
We are trying to implement WCCP in our network for LAN and VPN users. Here's a little info about our network:
- WCCP redirection is configured our cisco 4500, connected directly to the proxy server
- We have 2 VPN appliances for remote access, VPN#1 is cisco ASA 5525 (IPsec IKEv1 VPN), and VPN#2 is firewall from other vendor (SSL VPN)
- DHCP server for VPN users is in each respective firewall
We have successfully setup WCCP on our cisco 4500, here's the snippet configuration:
ip wccp 0 group-list 22 password XXX
interface gigabit ethernet 5/1
description PROXY_SERVER
no switchport
ip address 10.10.11.1 255.255.255.252
interface gigabit ethernet 5/2
description CONNECT_TO_LAN
no switchport
10.10.11.4 255.255.255.252
ip wccp 0 redirection in
interface gigabit ethernet 5/3
description CONNECT_TO_FW_VPN1 (ASA)
no switchport
10.10.10.1 255.255.255.0
interface gigabit ethernet 5/4
description CONNECT_TO_FW_VPN2
no switchport
10.10.20.1 255.255.255.250
access-list 22 permit 10.10.11.2
We have no issue in our proxy server configuration as for our LAN and VPN#2 users they can successfully browse the internet transparently after WCCP implementation. (WCCP redirection works)
but for our VPN#1 users, which are served by ASA, they're unable to browse the internet without explicit proxy configuration.
The same redirection is applied on those 3 links (LAN, VPN#1, and VPN#2) but why it is only not working on VPN#1? Please advise.
here's the snippet of our deployment showing our cat 4500 and ASA
FYI:
- our other firewall (VPN#2) deployed in the same condition as ASA, where inside interface is in the same IP subnet as the VPN users.
- please dont go off topic and talk about solution such as split-tunneling, etc, we just want to focus about WCCP in this topic
Thank you
0 Replies 0
