WCCP web cache on ASR 1002 with SQUID Proxy
bobbydazzler
Bonjour!
I have been trying to set up a web proxy (squid) with an ASR 1000 using GRE Redirect/Return. The problem I am facing is that it seems that the ASR is not redirecting anything to the proxy cache server. Here is the snippet of the relevant config (when I do the same on a 7301 it works fine), is there anything I have missed?
Global config:
no ip wccp variable-timers
ip wccp check services all
ip wccp source-interface Port-channel1.589
ip wccp web-cache redirect-list 120 group-list 10
Interface connected to the proxy cache server (squid) - cache server IP is on 10.5.89.11
 encapsulation dot1Q 589
 ip address 10.5.89.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
end
LAN interface:
interface Port-channel1.598
 encapsulation dot1Q 598
 ip address 100.65.0.1 255.255.0.0
 ip nat inside
 ip wccp web-cache redirect in
end
ACLs:
=> I don't see any matches for the ACL 120 :-((((
Standard IP access list 10
    10 permit 10.5.89.11 (17113 matches)
Extended IP access list 120
    10 permit tcp any any eq www
The proxy cache register :
#sh ip wccp web-cache detail
WCCP Client information:
	WCCP Client ID:          10.5.89.11
	Protocol Version:        2.00
	State:                   Usable
	Redirection:             GRE
	Packet Return:           GRE
	Assignment:              HASH
	Connect Time:            00:39:46
	Redirected Packets:
          Process:               0
          CEF:                   0
	GRE Bypassed Packets:
          Process:               0
          CEF:                   0
	Hash Allotment:          256 of 256 (100.00%)
	Initial Hash Info:       00000000000000000000000000000000
	Assigned Hash Info:      FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Global WCCP information:
    Router information:
	Router Identifier:                   10.5.89.1
        Configured source-interface:         Port-channel1.589
    Service Identifier: web-cache
	Number of Service Group Clients:     1
	Number of Service Group Routers:     1
	Total Packets Redirected:            0
          Process:                           0
          CEF:                               0
          Platform:                          0
	Service mode:                        Open
	Service Access-list:                 -none-
	Total Packets Dropped Closed:        0
	Redirect access-list:                120
	Total Packets Denied Redirect:       0
	Total Packets Unassigned:            0
	Group access-list:                   10
	Total Messages Denied to Group:      0
	Total Authentication failures:       0
	Total GRE Bypassed Packets Received: 0
          Process:                           0
          CEF:                               0
          Platform:                          0
	GRE tunnel interface:                Tunnel0
Any idea where/what I could be looking at?
bobbydazzler
Just in case some people come across the same pb.
I fixed the problem by using l2-redirect instead of using GRE redirect/return. Using GRE wasn't working and on top of that the CPU usage went up the roof! The config on the ASR is unchanged. When possible, using l2-redirect is much better anyway as it is processed by the hardware and not the software (when using GRE it is handled by the software).
guycht01#sh ip wccp web-cache detail
	State:                   Usable
	Redirection:             L2
	Packet Return:           L2
	Assignment:              HASH
	Connect Time:            03:19:18
	Redirected Packets:
          Process:               0
          CEF:                   0
          Platform:              15660019
          Process:               0
          CEF:                   0
Here is the relevant config I did on squid:
wccp2_router 10.5.89.1
wccp_version 4
wccp2_forwarding_method l2
wccp2_return_method l2
wccp2_service standard 0
And the iptables rule:
iptables -t nat -A PREROUTING -i INTERFACE-CONNECTED-toASR -p tcp -m tcp --dport 80 -j DNAT --to-destination 10.5.89.11:3128
This is a very useful link regarding SQUID and WCCP
https://wiki.squid-cache.org/Features/Wccp2
My set up works for HTTP with  Squid Cache: Version 3.5.23 et ASR 1002 IOS 15.5(3)S2
Best regards
5 Replies 5
which IOS version are you running on your ASR ?
Hi Georg,
We are using Version 15.5(3)S2
Best regards
Hello
Have you tried applying it to redirect egress and just with the web proxy address?
ip wccp web-cache
interface port 589
ip wccp web-cache redirect out
access-list 10 permit 10.5.89.11
ip wccp web-cache group-list 10
res
Paul
Kind Regards
Paul
Hello Paul,
Thank for your suggestion.
I have tried what you suggested but still nothing going to the proxy :-( Just to make sure I understood correctly here is the config I did:
#sh run | i wccp
ip nat inside
end
no ip redirects
no ip unreachables
no ip proxy-arp
end
bobbydazzler
	State:                   Usable
	Redirection:             L2
	Packet Return:           L2
	Assignment:              HASH
	Redirected Packets:
          Process:               0
          CEF:                   0
          Platform:              15660019
          Process:               0
          CEF:                   0
wccp_version 4
Best regards
