Web based authentication on 6500 IOS
sachin
Level 5
Level 5
can any body gives me the configuration required for doing Web based authentication on 6500 IOS. I am running 12.2SX 33 which supports this feature. I tried ip admission commands but it seems ACL need to be define.
My scenerio is
Switchport -----Switch ---Int Vl 60 ---- Radius server. I wanna do web based authentication on switchport
Please tell me what kind ACL config is required.
Not applicable
Web-based authentication can be configured only on access ports, and not on trunk ports. Default ACL must be configured on the interface before configuring web-based authentication. For more information refer the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/webauth.html#wp1067205
I have already tried this config. But some how it is not working. Do you have any running full config ? Specially if you can give me access-list commands that will be really helpful.
I debugged ip admission api , it gives following errors -
01:41:43: ip_admission_api:[EAPoUDP (08)] not configured on [Vlan60]
01:41:45: ip_admission_api:[EAPoUDP (08)] not configured on [Vlan60]
01:41:47: ip_admission_api:[EAPoUDP (08)] not configured on [Vlan60]
01:41:48: ip_admission_api:[EAPoUDP (08)] not configured on [Vlan60]
01:41:49: ip_admission_api:[EAPoUDP (08)] not configured on [Vlan60]
I dont understand why udp messages are generated. Do we need EAPoUDP config also.
