01-27-2009 03:39 PM - edited 03-06-2019 03:41 AM
My 2610 had been participating just fine in my little OSPF lab; I went into config-if mode and gave its Eth0 interface the ip address I wanted. Then I realized I needed to re-assign the addresses in its area; and suddenly when I give the
config)# int e0
command, it says "%Incomplete command." I've tried every variation of what the "?" facility says I should say in global config mode; and still with the "%Incomplete command" message.
This also now occurs when I do a "show interface e0" command in EXEC mode (user or privileged).
Why the heck is it doing this?
Solved! Go to Solution.
01-27-2009 03:57 PM
Can you look at show ip int brief? Can you see ethernet 0 or ethernet 0/0?
The ethernet interface on this platfrom is onboard and on slot 0 hence the system would see it as e0/0 not e0
Router(config)#int e0
% Incomplete command.
Router(config)#inter e0/0
Router(config-if)#end
Router#show int e0
Router#show int e0/0
Ethernet0/0 is administratively down, line protocol is down
Hardware is AmdP2, address is 0030.853b.ad60 (bia 0030.853b.ad60)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Hope that helps.
01-27-2009 03:57 PM
Router#show int e0
Hope that helps.
01-27-2009 04:08 PM
The twilight zone thing is; I'd have >>>SWORN<<< that I got into that interface just fine earlier in the day by only calling it "e0"
Maybe my fingers magically slipped at those moments and I accidentally typed the /0 (I've done stranger things.)
Anyway.....THANKS!
