12-08-2010 12:05 PM - edited 03-06-2019 02:25 PM
All,
I have a weird issue that deals with 2 routers and a wireless ap. The ap is a Cisco 1130 series, and it has 1 address on it.Cisco AP:ip: 192.168.1.5gw: 192.168.1.1
mask: /24
The site has 2 routers:
192.168.1.3 - primary - over mpls192.168.1.4 - voice router - over dedicated t1
My monitoring server address is 192.168.50.200.The problem is that for some reason, the wireless ap is arping for the monitoring server address. It then gets to the voice router and starts to lose packets. I've tried to clear arp on the AP, but that's not doing a thing (almost like it's a static entry, but it's not).So, what I've done to fix it in the meantime is add a static route on the voice router to point the monitoring server back to my main router. That works, but what I need to know is what situation would cause a device to arp for an address that's not local? I've never seen that before....
John
Solved! Go to Solution.
12-08-2010 12:15 PM
Sounds like a proxy arp issue. See if you have the configuration option to enter the "no ip proxy arp" on the AP interface configuration.
Then remove the static route on the server and clear arp on the server and any L2 device in between.
12-08-2010 12:15 PM
12-08-2010 12:19 PM
Right after I posted, I got your message and you were right on....
John
12-08-2010 12:16 PM
Fixed....
John
