What are most people using VXLAN for?
carl_townshend
Hi All
I would like to know what the most common use case is for VXLAN these days? are most people using it for tunnelling vlans between sites?
Cheers
balaji.bandi
Virtual extensive local area network (VXLAN) is a protocol for running a Layer 2 network and stretching it over a Layer 3 network.
in traditional VLAN you can have max of 4K LVAN, with VXLAN you can mitigate this issue in bigger network. L2 STP Loops gone.
SD-Access Mainly use VXLAN as data plan over LISP as controlplan.
more information can be find :
https://blogs.cisco.com/datacenter/vxlan-taking-a-more-strategic-role-in-cloud-networks-with-support-across-cisco-fabrics-and-switching-platforms
BB
Hi Balaji
I thought it was the case,
are people generally mapping the vlan to a single vni or mapping multiple vlans to a vni? any reason you would choose one over the other?
also am I right saying that the vni number has to start from 4096 to 16,777,215 ? so for example I would have to map vlan 10 to 4096 and not vlan 10 to vni 10?
cheers
