what causes cpu spikes in switches both L2 and L3 ?
carl_townshend
Hi All
Can anyone tell me what things can use up the cpu on a switch?
would it be things going to the switch rather than through it ?
cheers
Mark Malone
It can be a number of things these are just some, broadcast storms, layer 2 loop , jammed process in the switch itself, virus on the network, faulty nics flooding and sending irregular traffic , you need to look at the show proc cpu sorted while its happening that will show give you an idea of whats going on, if you cant catch it live use an EEM script to register anytime that the cpu spikes above 70
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, it might be some traffic directed to the switch, rather than traffic through the switch, that causes the switch's CPU to jump.  This because the switch usually has special hardware for dealing with transit traffic.
However, there are internal processing events that can cause the CPU to jump.  There's also situations where, for some reason, the special hardware that normally handles transit traffic sends that traffic to the CPU for processing.
As Mark has noted, CPU process usage stats often provide insight into the cause of CPU usage.
