What code to load onto 3750G?
KMNRuser
I am currently the feature in Solarwinds wherein you can move firmware up and down on boxes.
I am trying to find the IOS for a "WS-C3750G-24PS".
The issue i am having when you type the "G" in the software search on software.cisco.com is that it does not show any results when you type the G..it is as if there are not any 3750G data in the database.. see below
So you can see the dilema.
Can anyone advise where i am able to pull the software down from?
Thanks in advance,
KMNRuser
M02@rt37
Hello @KMNRuser
For 3750G,  the latest here 12.2(55)SE and 15.0(2)SE.
Reference: https://community.cisco.com/t5/switching/ws-3750g-24ps-firmware/td-p/4619665
Best regards
Hi @KMNRuser
 As 3750 is end of life, you will not find IOS for this model exactly.
I suggest to you download the software to Catalyst 3750V2-24PS Switch and try to use in yours.
Ah yes.. EOL.  I had not given that any thought.  That is a fair enough answer.
I might be a bit hesitant to throw code at a box that isnt specifically for that box.
Kevin
That´s correct.
M02@rt37
Hello @KMNRuser
Best regards
