what does mean System FCS error frames?
HANOH CHA
Community Member
I have a C2960G that is some issue.
This problem is ping success DA(GOOGLE),also it doesnt  open same web site for port 0/1 ~ 0/4.
other port successed ping and web site that just changed port.
what does reason this problem?
I think 0/1 ~0/4 port is same ASIC that is fault.
Let me know what is problem?
     Transmit GigabitEthernet0/1              Receive
   1316853346 Bytes                       4196492763 Bytes
    319528358 Unicast frames               337351001 Unicast frames
    208877933 Multicast frames                 12929 Multicast frames
     34631197 Broadcast frames                765178 Broadcast frames
            0 Too old frames              4094646794 Unicast bytes
            2 Deferred frames                1817312 Multicast bytes
            0 MTU exceeded frames          100026768 Broadcast bytes
            3 1 collision frames                   0 Alignment errors
            0 2 collision frames                  10 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   2 Collision fragments
            0 6 collision frames
            0 7 collision frames            95891476 Minimum size frames
            0 8 collision frames           116359585 65 to 127 byte frames
            0 9 collision frames            59470400 128 to 255 byte frames
            0 10 collision frames           28961467 256 to 511 byte frames
            0 11 collision frames           14288550 512 to 1023 byte frames
            0 12 collision frames           23157642 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 2 Symbol error frames
           11 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  2 Invalid frames, too small
     98381126 64 byte frames                       0 Valid frames, too small
    200223276 127 byte frames
     39551381 255 byte frames                      0 Too old frames
    176560369 511 byte frames                      0 Valid oversize frames
     29278568 1023 byte frames               3390830 System FCS error frames
     22433608 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            2 Good (1 coll) frames
            0 Good (>1 coll) frames
Reza Sharifi
Excessive errors for certain counters usually indicate a problem. When       you operate at half-duplex setting, some data link errors incrementing in Frame       Check Sequence (FCS), alignment, runts, and collision counters are normal.       Generally, a one percent ratio of errors to total traffic is acceptable for       half-duplex connections. If the ratio of errors to input packets is greater       than two or three percent, performance degradation can be noticed.
In half-duplex environments, it is possible for both the switch and the       connected device to sense the wire and transmit at exactly the same time and       result in a collision. Collisions can cause runts, FCS, and alignment errors       due to the frame not being completely copied to the wire, which results in       fragmented frames.
When you operate at full-duplex, errors in FCS, Cyclic Redundancy       Checks (CRC), alignment, and runt counters must be minimal. If the link       operates at full-duplex, the collision counter is not active. If the FCS, CRC,       alignment, or runt counters increment, check for a duplex mismatch. Duplex       mismatch is a situation where the switch operates at full-duplex and the       connected device operates at half-duplex, or vice versa. The results of a       duplex mismatch are extremely slow performance, intermittent connectivity, and       loss of connection. Other possible causes of data link errors at full-duplex       are bad cables, faulty switch ports, or NIC software/hardware issues. See the       Common Port and Interface Problems section of       this document for more information.
more info:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfd6.shtml
Leo Laohoo
Look at the Transmit column.  You have "11" Late collisions.  You have "3" 1 collision frames.
Look at the Receive column.
Yes, your Systems FCS is very high.
Run a TDR test from your 2960G.
HANOH CHA
Community Member
now it just dont use port before i used to be usage with port 0/1 -0/4
and we already physical test.
GigabitEthernet0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is aca0.162c.7c01 (bia aca0.162c.7c01)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 1w5d, output 00:35:25, output hang never
Last clearing of "show interface" counters 1w0d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1653 packets input, 156708 bytes, 0 no buffer
Received 582 broadcasts (310 multicasts)
9 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 310 multicast, 0 pause input
11302 packets output, 2690664 bytes, 0 underruns
0 output errors, 3 collisions, 0 interface resets
0 babbles, 11 late collision, 0 deferred
I replace the HW and than it will be ok.
at the time its problems, if you have it, you can be replacememt it.
thank you for answering.
