What does 'not a gateway' mean?
robert.huang
Hi All,
Today I issued "show ip traffic" on the 2960 Catalyst switch, and found '4554734 not a gateway' in Rcvd section. Somebody here can tell me what 'not a gateway' mean? Is that normal?
Much appreciated.
Harold Ritter
Robert,
My guess is that you have configured an IP address on the 2960 for management purposes only (it is not configured as a router) but some other device on that subnet is trying to use it as it default gateway.
John Blakley
It's normal. It means that the packet isn't routed out a gateway and stays on the local segment.
HTH,
John
*please rate if helpful*
HTH, John *** Please rate all useful posts ***
John,
This counter is incremented when the device is not configured as an ip router (no ip routing) and you receive an ip packet for a destination that is not your local IP address.
Harold Ritter
Robert,
