What does the errors in the output below indicates, There are no Fastethernet interfaces.
gafolabis
01:01:50: %SYS-5-RELOAD: Reload requested
C3500XL Boot Loader (C3500-HBOOT-M) Version 12.0(5.3)WC(1), MAINTENANCE INTERIM SOFTWARE
Compiled Mon 30-Apr-01 07:51 by devgoyal
starting...
Base ethernet MAC Address: 00:07:85:bb:6c:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 2 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 1813504
flashfs[0]: Bytes available: 1799168
flashfs[0]: flashfs fsck took 3 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c3500xl-c3h2s-mz.120-5.WC17"...###################################################################################################################################################################################
File "flash:c3500xl-c3h2s-mz.120-5.WC17" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:04 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
Initializing C3500XL flash...
flashfs[1]: 2 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 1813504
flashfs[1]: Bytes available: 1799168
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete.
...done Initializing C3500XL flash.
C3500XL POST: System Board Test: Passed
C3500XL POST: Daughter Card Test: Passed
C3500XL POST: CPU Buffer Test: Passed
C3500XL POST: CPU Notify RAM Test: Passed
C3500XL POST: CPU Interface Test: Passed
C3500XL POST: Testing Switch Core: Passed
C3500XL POST: Testing Buffer Table: Passed
C3500XL POST: Data Buffer Test: Passed
C3500XL POST: Configuring Switch Parameters: Passed Error.
Failed address lines - walking ones.
sent:
0x00000: 0x0 0x0 0x0 0x0 0x0 0x0
0x00001: 0x1 0x1 0x1 0x1 0x1 0x1
0x00002: 0x2 0x2 0x2 0x2 0x2 0x2
0x00004: 0x3 0x3 0x3 0x3 0x3 0x3
0x00008: 0x4 0x4 0x4 0x4 0x4 0x4
0x00010: 0x5 0x5 0x5 0x5 0x5 0x5
0x00020: 0x6 0x6 0x6 0x6 0x6 0x6
0x00040: 0x7 0x7 0x7 0x7 0x7 0x7
0x00080: 0x8 0x8 0x8 0x8 0x8 0x8
0x00100: 0x9 0x9 0x9 0x9 0x9 0x9
0x00200: 0xA 0xA 0xA 0xA 0xA 0xA
0x00400: 0xB 0xB 0xB 0xB 0xB 0xB
0x00800: 0xC 0xC 0xC 0xC 0xC 0xC
0x01000: 0xD 0xD 0xD 0xD 0xD 0xD
0x02000: 0xE 0xE 0xE 0xE 0xE 0xE
0x04000: 0xF 0xF 0xF 0xF 0xF 0xF
0x08000: 0x10 0x10 0x10 0x10 0x10 0x10
0x10000: 0x11 0x11 0x11 0x11 0x11 0x11
recv:
0x00002: 0x2 0x2 0x2 0x0 0x2 0x2
0x00004: 0x3 0x3 0x3 0x1 0x3 0x3
0x00020: 0x6 0x6 0x6 0x4 0x6 0x6
0x00040: 0x7 0x7 0x7 0x5 0x7 0x7
0x00200: 0xA 0xA 0xA 0x8 0xA 0xA
0x00400: 0xB 0xB 0xB 0x9 0xB 0xB
0x02000: 0xE 0xE 0xE 0xC 0xE 0xE
0x04000: 0xF 0xF 0xF 0xD 0xF 0xF
GDS RA POST: RAM Failed Address line test
Del Mar Failure (2nd Del Mar): Failed Address RAM Table POST
C3500XL POST FAILURE: Failed Address RAM Table POST
C3500XL POST: Ethernet Controller Test: Passed
C3500XL POST FAILURE: MII Test: Failed
C3500XL POST FAILURE: front-end post: reg_invoke_gds_set_tx_enable failed for port 0
C3500XL POST FAILURE: Initialization/POST failed
C3500XL POST FAILURE: AT: Failing because system POST failed
cisco WS-C3524-PWR-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
Processor board ID FAA0541D04Q, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:85:BB:6C:00
Motherboard assembly number: 73-4033-07
Power supply part number: 34-0968-01
Motherboard serial number: FAA0539HN1R
Power supply serial number: LIT04242047
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3524-PWR-XL-EN
System serial number: FAA0541D04Q
C3500XL INIT: Complete
00:00:10: %LINK-4-ERROR:  is experiencing errors
00:00:15: %SYS-5-RESTART: System restarted --
         --- System Configuration Dialog ---
At any point you may enter a question mark '?' for help.
Use ctrl-c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.
Continue with configuration dialog? [yes/no]: no
Press RETURN to get started.
Switch#sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
no cgmp
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
no ip directed-broadcast
no ip route-cache
mac-address-table aging-time 0
line con 0
transport input none
stopbits 1
line vty 5 15
end
Michael Odom
Level 4
Level 4
Looks like you have a hardware problem.  You will likely have to replace the switch.
Leo Laohoo
You need to RMA this switch.
