What happen to vlan tag info when passing through a router
haluochen9988
What happen to the vlan tag information when packet pass through a router? Will that tag info stripped off or still stay with the packet when switch on the other side receive the packet?
2 Accepted Solutions
A VLAN is terminated by a router. So the router will strip off the tag, but if the outgoing interface is also a trunk, a new VLAN-tag can be created based on that VLAN. If the router-ingress interface is attached to an access-port of the switch, then of course the router won't see any VLAN-tag.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If traffic will actually be routed, i.e. a L3 hop, ingress Ethernet frame is dropped and egress Ethernet frame is new.  VLAN tag information would not carry over.
Joseph W. Doherty
Disclaimer
Posting
