what happens if you have 2 eigrp processes running between 2 routers
carl_townshend
hi all, if I have 2 routers, what happens if you have 2 eigrp processes running between them advertising the same routes in each AS. Which one would work the lower AS number process ?
royalblues
Level 10
Level 10
It is very difficult to identify which AS would ideally be used to route the traffic when the same routes are advertised out 2 processes.
But i just did a quick test by connecting 2 routers with multiple links and each link was part of one eigrp process and advertised a common subnet via both EIGRP proccesses. EIGRP AS with a lower AS number was preferred
Narayan
