What Happens when an interface Attached to a Port-Channel goes down?
MAnoj Kumar
Beginner
Beginner
I do know the Speed will reduce ( Duh !) , Apart from that any STP recalculation will happen ?
Anup Sasikumar
Beginner
Beginner
As far as my understanding goes , Interfaces which are part of a Port Channel is exempted from STP calculation . I believe , configuring bundling ports to a Port Channel can be considered as a quick way to use all the trunk ports connected .
Anup
Joseph W. Doherty
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Well if it's the only remaining channel link, the port-channel goes down.  If not the only remaining channel link, the port-channel continues without it.  As you note, you lose bandwidth and I believe traffic will be rehashed across the remaining channel links, which can result in less optimal load distribution.
Protocols like STP or a routing protocol shouldn't see a link outage or flap.
Recognize Your Peers
