PBR feature not working on Nexus 5K
rashpal_saini
All
i am trying to enable policy based routing feature on Nexus switch, but i am getting error, command not available.
 show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2013, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 6.0(2)N1(2a)
  system:    version 6.0(2)N1(2a)
  Power Sequencer Firmware:
             Module 1: version v1.0
             Module 3: version v5.0
  Microcontroller Firmware:        version v1.2.0.1
  SFP uC:    Module 1: v1.0.0.0
  QSFP uC:   Module not detected
  BIOS compile time:       05/09/2012
  kickstart image file is: bootflash:///n5000-uk9-kickstart.6.0.2.N1.2a.bin
  kickstart compile time:  5/20/2013 9:00:00 [05/20/2013 17:43:34]
  system image file is:    bootflash:///n5000-uk9.6.0.2.N1.2a.bin
  system compile time:     5/20/2013 9:00:00 [05/20/2013 20:18:17]
Hardware
  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor")
  Intel(R) Xeon(R) CPU         with 8262944 kB of memory.
  Processor Board ID FOC17165AVX
  Device name: NFRA1L3CORE1
  bootflash:    2007040 kB
Kernel uptime is 468 day(s), 3 hour(s), 45 minute(s), 44 second(s)
Last reset
  Reason: Unknown
  System version: 6.0(2)N1(2a)
  Service:
plugin
  Core Plugin, Ethernet Plugin
 show feature
Feature Name          Instance  State
Flexlink              1         disabled
amt                   1         disabled
bgp                   1         enabled
cts                   1         disabled
dhcp                  1         enabled
dot1x                 1         disabled
eigrp                 1         disabled
eigrp                 2         disabled
eigrp                 3         disabled
eigrp                 4         disabled
eth_port_sec          1         disabled
fcoe                  1         disabled
fcoe-npv              1         disabled
fex                   1         enabled
glbp                  1         disabled
hsrp_engine           1         enabled
interface-vlan        1         enabled
isis                  1         disabled
isis                  2         disabled
isis                  3         disabled
isis                  4         disabled
lacp                  1         enabled
ldap                  1         disabled
lldp                  1         enabled
msdp                  1         disabled
oim                   1         disabled
ospf                  1         enabled
ospf                  2         enabled (not-running)
ospf                  3         enabled (not-running)
ospf                  4         enabled (not-running)
ospfv3                1         disabled
ospfv3                2         disabled
ospfv3                3         disabled
ospfv3                4         disabled
pbr                   1         disabled
pim                   1         disabled
poe                   1         disabled
private-vlan          1         disabled
privilege             1         disabled
NFRA1L3CORE1# configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
NFRA1L3CORE1(config)# feature ?
  bgp             Enable/Disable Border Gateway Protocol (BGP)
  cts             Enable/Disable CTS
  dhcp            Enable/Disable DHCP Snooping
  dot1x           Enable/Disable dot1x
  eigrp           Enable/Disable Enhanced Interior Gateway Routing Protocol (EIGRP)
  fcoe            Enable/Disable FCoE/FC feature
  fcoe-npv        Enable/Disable FCoE NPV feature
  fex             Enable/Disable FEX
  flexlink        Enable/Disable Flexlink
  hsrp            Enable/Disable Hot Standby Router Protocol (HSRP)
  http-server     Enable/Disable http-server
  interface-vlan  Enable/Disable interface vlan
  lacp            Enable/Disable LACP
  msdp            Enable/Disable Multicast Source Discovery Protocol (MSDP)
  ntp             Enable/Disable NTP
  ospf            Enable/Disable Open Shortest Path First Protocol (OSPF)
  ospfv3          Enable/Disable Open Shortest Path First Version 3 Protocol (OSPFv3)
  pim             Enable/Disable Protocol Independent Multicast (PIM)
  port-security   Enable/Disable port-security
  private-vlan    Enable/Disable private-vlan
  privilege       Enable/Disable IOS type privilege level support
  ptp             Enable/Disable PTP
  rip             Enable/Disable Routing Information Protocol (RIP)
  scp-server      Enable/Disable SCP server
  sftp-server     Enable/Disable SFTP server
  ssh             Enable/Disable ssh
  tacacs+         Enable/Disable tacacs+
  telnet          Enable/Disable telnet
  udld            Enable/Disable UDLD
  vpc             Enable/Disable VPC (Virtual Port Channel)
  vrrp            Enable/Disable Virtual Router Redundancy Protocol (VRRP)
  vtp             Enable/Disable Vlan Trunking Protocol (VTP)
feature       feature-set
NFRA1L3CORE1(config)# feature pbr
Can someone suggest me what can be the issue? Switch have LAN_ENTERPRISE_SERVICES_PKG license.
Rashpal Singh
Reza Sharifi
See table-5 in this link:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html#fntarg_13
Note 19:
The LAN_BASE_SERVICES_PKG license needs to be installed in order to use the LAN_ENTERPRISE_SERVICES_PKG license.
Thanks Reza
Switch have both the LAN_BASE_SERVICES_PKG and LAN_ENTERPRISE_SERVICES_PKG license installed.
Rashpal Singh
