What happens When
fb_webuser
Level 6
Level 6
A default route is given on 2 stub routers connected to each other...and where a pc pings an unknown network, what happens
Posted by WebUser Ganesh Kandari from Cisco Support Community App
The packet will play ping-pong between these two routers until the TTL counts down to zero.
You can easily simulate that with GNS3.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
marcjones84
As there would be no longest match route in the route table, the static default would be used, pointing towards the other router. Then on the other router, the exact same thing would happen.
As karsten said, the packets would bounce back and forth until the TTL was decremented. If you set this up in GNS3 or on a lab, a traceroute would also show the routing loop.
