What is diffenece between Clockrate and Bandwidth??
abhi-adte
Actually If I change the clockrate and define the bandwidth (less and High) what will happen serail interface???
can u suggest...
Edison Ortiz
clockrate will be the actual speed used on the interface. If you configure a clockrate of 128kbps, and bandwidth of 256kbps - 128kbps will be your limit on that interface and routing protocols as well as QoS will see the interface as a 256kbps line.
It's a recommendation to match both values but the clockrate is the one that dictates the speed of the line. Bandwidth is there to inform QoS and routing protocols how fast the link is.
Additionally, if you don't enter a bandwidth information under the serial interface - it defaults to a T1 speed.
Edison
Edison Ortiz
Edison
burleyman
Level 8
Level 8
Great info Edison.....+5
Mike
abhi-adte
Thanks sir
