what is difference between iBGP and EBGP ?
crscrsone
Any difference between iBGP and EBGP
vladrac-ccna
Level 5
Level 5
There are many differences between IBGP and EBGP:
for IBGP peers dont need to be directly connected.
next-hop IP will not be changed when adv prefixes to another IBGP
Also, if you check the way BGP choose the best route to put in the routing table you'll see that EBGP is preferred.
But this is just a few things.
Vlad
IBGP is formed between Neighbors within the same AS whereas EBGP is formed between neighbors in different AS.
A route learnt from an IBGP peer will not be advertised back to another IBGP by default.
AS path is not prepended to the route when advertised to an IBGP peer.
Attributes like local preference are sent to the IBGP peers but not to an EBGP peer.
As VLAD has stated, under normal circumstances EBGP route is always preferred over an IBGP route (exception are if u configure BGP deterministic-med & BGP always-compare-med)
I will not agree with VLAD on the 1st point though. Even EBGP peers need not be directly connected. The only requirement is reachability to the remote peer with appropriate ebgp-multihop configuration
HTH, rate if it does
Narayan
devang_etcom
Level 7
Level 7
BGP can run in two modes that each has a very different behavior when advertising routing information.
EBGP: external BGP runs between routers in different ASs
IBGP: internal BGP runs between routers in the same AS
EBGP: routes received from an EBGP peer can be advertised to EBGP and IBGP peers
IBGP: routes received from an IBGP peer cannot be advertised to another IBGP peer but can be advertised to an EBGP peer
regards
Devang
in addition to the other posts, have a look at this link as well, which is a very comprehensive paper on BGP:
BGP Fundamentals
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/icsbgp4.htm#wp10579
HTH,
GNT
