what is difference between Switch with IP base & IP service
knaik99
what is difference between Switch with IP base & IP service?
Is it related to IOS?
Mark Malone
Its related to features available through the license you upload to the device , ipbase gives you some Ip features ip services gives you all features including BGP ,PBR etc , thats the most expensive of the 3
The IP Base feature set includes advanced quality of service (QoS), rate limiting, access control lists (ACLs), and basic static and Routing Information Protocol (RIP) functions. Dynamic IP routing protocols (Open Shortest Path First (OSPF), BGPv4, Enhanced Interior Gateway Routing Protocol (EIGRP)) are available only on the IP services image.
The IP Services image provides a richer set of enterprise-class features, which includes advanced hardware-based IP unicast and IP Multicast routing. Support for IPv6 Layer 3 switching in hardware is also available with the addition of the Advanced IP Services license to either the IP Base or the IP Services images. Both the IP base Image and the IP services image allow for Layer 3 and Layer 4 lookups for QoS and securit
