what is ESP-8/16 Administration on a cisco switch 3750x
rfuentes1111
Hi Team,
Need help with the following issue i just deploy a cisco switch 3750x. i'm getting the following screen when i telnet to it.
enter password:
ESP-8/16 Administration - Top Menu
0 -> Server configuration
1 -> Serial port attributes
2 -> Serial port connection methods
3 -> Port interface
4 -> Send break
5 -> Status
6 -> Debug
7 -> Change password
99 -> Exit
enter command:
Does anybody have seen this message this is my fist time i see this message I have deploy all my switches and never seen this before if someone can help thank you.
Leo Laohoo
The output above is NOT from any Cisco appliance.  You sure of the IP address?
"ESP-8/16" sounds like an Avocent serial hub.
My cisco switch 3750x is connected to my NK7 via 10g aqua fiber and sometime I'm able toget to the normal telnet window and the IP address is the right IP.
